ARI-500 and ALS 1300 interfacing band changing
W7NIK
W7NIK Member ✭✭
edited November 2019 in New Ideas
Ok I would like to give out this information.
This is my BCD log data 160m, 10m etc.
04:35:40 (TX): 0x00
04:35:40 (TX): 0x09
04:36:53 (TX): 0x00
04:36:54 (TX): 0x08
04:36:57 (TX): 0x00
04:36:58 (TX): 0x07
04:37:02 (TX): 0x06
04:37:10 (TX): 0x00
04:37:11 (TX): 0x05
04:37:15 (TX): 0x00
04:37:20 (TX): 0x03
04:37:25 (TX): 0x00
04:37:30 (TX): 0x02
04:37:35 (TX): 0x00
04:37:35 (TX): 0x01
According to Ameritron , the  procedure is as follows, ARI-500 In stand by, Rear A/B of Amp RJ45 cables goes to the AMP A/B of the ARI-500, ( Manuals are tricky, they do not give this information)  They mention the remote panel :(
 Plug in the  RJ-USB600 to the Flex radio, in USB cables the settings are
      BCD,
  ACTIVE SLICE,
    HF_BCD,
 ACTIVE HIGH ,
RCA cable from the  TX-1 port to the Relay of AMP. ( Not the PTT weird )
Now the amp is still off,  The operate switch is in stand by . IT stays in stand by .
Band switch on REM
Turn on Amp , wait a full 2 minutes , Go to  the ARI-500 Move  the toggle from  stand by to operate .
My mistakes were , active low on the usb, settings, not waiting two minutes, I guess the amp goes into a secret fault . The operate / stand-by  on the amp was on operate,  I plugged in the RCA cable  into  relay into the PTT.  .
 I was also told by Ameritron the ARI-500 can key the AMP  ?  with out the RCA jack ?
My FTDI cable was bad, and had to trouble shoot the problems .
This was a big  learning curve , thank you for all the support on this community .
 Yes the amp switches, and the Steppir follows Freq.
Flex is awesome, just save your settings , click the wrong thing nothing works. Reload the last profile all good again .
0 votes
In Review · Last Updated
