Dax
Bernie Barber
Dax
What do you have for your playback and record audio channels? Have you enabled DAX on the relevant slice (alongiside DSP, USB, S/RIT for the channel that you want that slice to connect to? What version of Windows(?) are you using? Has this problem just occurred or is this an initial setup? Which DAX version are you using?
What version of SSDR DAX is installed on your PC. If its an older version, Dax had known issues with Windows audio device naming.. That problem was corrected in latest versions of V1, V2 & V3.
AL, K0VM
- 111 Aurora
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
