How To Recover Minimized SmartSDR Window?
Ian Snow
I recently updated to SmartSDR V 2.6.1. The app opens with a single Panafall and Slice Receiver (A) filling the screen. The normally right-side pane with the TX-P/CW-PHNE-RX-EQ windows is missing. After a thorough search of the documentation and experimentation I have failed to discover how to maximize this oabe.
My next step was to reinstall V 2.5. I discovered in the top right corner a small box containing an arrow pointing to the top-right corner and the label "minimize". I clicked it and the TX-P/CW-PHNE-RX-EQ windows disappeared. Again, after a full day of searching the documentation and on-screen selections I failed to find how to restore the missing pane.
I then reverted to Ver 2.4.5(?) Like 2.5 the opp opened with the Panafall and TX-P/CW-PHNE-RX-EQ windows visible. Again I clicked the small top-right minimize 'button' and as expected the TX-P/CW-PHNE-RX-EQ windows closed and the Panafall expanded to occupy the whole screen. However, after reducing the size of the Panafall screen low and behold there was the TX-P/CW-PHNE-RX-EQ window hiding behind it. In the top-right corner was the "Pop in/out" button but this time the arrow pointed downward and clicking it restored the PanaFall with the TX-P/CW-PHNE-RX-EQ windows displayed .alongside. Voila -- or so I thought.
Reinstalling Ver 2.6.1 for the n-th time it opened with only the PanaFall screen displayed, as expected. I minimized that screen BUT no TX-P/CW-PHNE-RX-EQ windows behind it.
Can someone tell me how to restore the missing TX-P/CW-PHNE-RX-EQ windows? Is this problem somehow influenced by the new "running change" Profile feature? HELP
Levono T400 computer with Win 7 Home Premium, and
HP Desktop with Win 7 Professional SP1
Flex 6600
Ian VA3QT
Flex 6600
Ian VA3QT
I just tried to recreate your issue. Sure enough it disappears. I saw no way to bring it back by clicking on the same location that took it away(top right). But I also noticed that it does not go away entirely. What happens is that it is changed into its own window and on my Win 7 machine I had a tab at the bottom of the screen that I could click on to bring it back.
Edit to add: By a tab at the bottom I mean that instead of having the usual 3(SSDR, CAT, DAX) I have 4. The forth being your missing segment.
Thank-you John. I had expected that there would be a hidden window behind the SDR icon on the task bar but not so. The fact you got a fourth icon is even better. I'll give it another day or two and if no one responds with the solution I'll bump the problem upstairs. Thanks again.
Ian VA3QT0 -
Your very welcome Ian. If the above is happening to you, you may wish to do a search for how to either hide tabs in windows or how to find them. Maybe, just maybe your system is hiding it from you. Either way, good luck with it.
- 715 The Flea Market
- 216 SmartSDR+
- 469 SmartSDR for Mac
- 130 Aurora
- 993 Genius Products
- 138 Antenna Genius
- 331 Shack Infrastructure
- 235 Networking
