Dax error again??? with 2.61
FISHULA X
Everything was fine with 2.61. But, yesterday, my laptop had a boot issue and I had to start windows from scratch. I saved all my important files on a flash drive. So today, I had to start the rebuild of my apps. So on a fresh Win 10 install I downloaded 2.61 and now the DAX AUDIO TX is missing using Voice Keyer. In the drop down DAX AUDIO TX is missing??? And when I open Dax I get TX driver Error. Any help is appreciated. As I said. I had 2.61 up and running fine no issues until I had to wipe Windows 10 and start from scratch. Is there a patch or something.
Thank you...73
Thank you...73
Too late now, but it's really worth learning how to make a image of your hard drive. After I mastered it with Active Disk Image, my blood pressure shot down 30 points.0 -
I tried that, I made backup with a flash drive with no avail. Dam Lenovo0
You're the second person within 10 hours that said they had to reinstall Windows to try and resolve an issue with 2.6.1
I too have issues with 2.6.1 but have not had to reinstall Windows 10. It's a drastic step to take. I'm using the 1803 build. What version of Windows 10 are you using?
https://community.flexradio.com/flexradio/topics/2-6-1-audio-drop-outs
Do you use System Restore Points? The default option is "Disabled". You need to activate it and it will save a copy of all your windows setting prior to any device or system changes. It's very easy to use and comes with windows.
https://www.windowscentral.com/how-use-system-restore-windows-10
Win 10 Home, 1607.0
I just don't know how to fix this issue>>>0
Well I got tired of playing games so, I finally fixed it. I replaced the 2.61 Dax with one that works and replaced it Works great now. All is 2.61 but Dax is from last update.. Now no issues.0
- 105 Aurora
