WSJT-X with 3.1.8
Michael N3LI
Michael N3LI Member ✭✭
edited August 2020 in Third-Party Software
After the 3.1.8 update, I'm having problems with audio in WSJT-X. Settings appear to be okay, and the same audio settings for fldigi work FB. But it goes into transmit, but no audio.
Anyone else with that problem?
  • [Deleted User]
    edited April 2020
    Works fine here
  • k3Tim
    k3Tim Member ✭✭✭
    edited May 2020
    No problems with update either.
    Troubleshooting from end to end,
       WSJT Tx audio device is selected and Pwr is set
       Windows Audio controls panel shows active signals on:
          Playback - DAX Audio TX and  Dax Reserved Mic Audio
          Recording - Dax Mic Audio and Dax Reserved Audio TX
      Flex Panels:
          P/CW - Activity on Level meter
          PHNE Low and High  filter passband correct
    GL/ K3Tim
  • Michael N3LI
    edited February 2020
    Turns out the update changed the channel the sound came out. It set the WSJT sound to mono. Changing it to left channel fixed the problem.
    WSJT-X was the only program the update messed with - at least for this update.
    Since turning off the Windows update service gets turned on every time I disable it, then reboot,  looks like I'm stuck with it on this computer.
    So the problem is "fixed" for a little while.
    - 73 Mike N3LI -
  • Mickey N4MB
    Mickey N4MB Member
    Here are the 4 ways you can permanently disable Windows updates. Use caution, you probably want some of those, but at least you can decide when:  https://www.easeus.com/todo-backup-resource/how-to-stop-windows-10-from-automatically-update.html
    Mickey N4MB
