Flex 5000 output power to amp reduction
Paul Krog
I am wanting to connect a FL-7000 Amp to my Flex 5000, and would like to connect the amp to different antenna port than #1. Also I want to have the other antenna connection to be limited to a selected drive power that is correct for the amp. Is there a procedure to automatically reduce power on that selected port. Thank you Paul KR5OG
DDUTIL has these capabilities with Autodrive and some Macros
Bret
WX7Y
Marcos, thanks. I will work with that, I already use DDUtil for other functions so I am familiar with it. Thanks again Paul KR5OG0
- 688 The Flea Market
- 105 Aurora
