Started Up into Maestro
Scott Oakland
I have the Flex 6400M with the latest 3.1.7.138 HW version. Today when I started up the Flex, it booted into Maestro instead of Flex 6400M on the front of the radio., All of my previous settings in the radio appeared to have gone back to default. When Is tarted DAX and CAT software it wouldn't connect to the Flex 6400M, but I had to select Maestro to get it to connect. It now says Maestro on the front of the radio. It all works, but what happened? Can I get it back to show Flex 6400M. It did this overnight and not sure what caused it. Thanks!
Wow - a good reason to hold off updating until the cause of this is determined. And a good reason to occasionally back up profiles and settings to a PC. I’m still on 2.4.9 until xDax and xCat support for v3 shows up.0
Can’t you just Turn off the Maestro completely by holding the power button down for about 15 seconds or so the Maestro will have a drag down screen to shut it clear down so the radio can’t see the Maestro and then turn the M control panel on the radios on? The frequency changes that I have seen follows the control device Maestro, iPad, iPhone, M control panel etc all have a different frequency when I bring mine up when ran normally. Bret0
I tried what you suggested. Now I cannot get a DAX channel open. Argh0
- 714 The Flea Market
- 210 SmartSDR+
- 467 SmartSDR for Mac
- 129 Aurora
- 993 Genius Products
- 138 Antenna Genius
- 331 Shack Infrastructure
- 235 Networking
