SmartSDR v3.1.7, v2.6.0, and v1.12.1 are Now Available
Tim - W4TME
Administrator, FlexRadio Employee admin
FlexRadio Systems announces the immediate availability of SmartSDR v3.1.7, SmartSDR v2.6.0, and SmartSDR v1.12.1. It is highly recommended that you download the appropriate version of the Release Notes to ensure an optimal software installation experience
SmartSDR 3.1.7 can be downloaded from the FlexRadio Systems website. SmartSDR v3.1.7 is a general release containing new features software fixes for version 3 of SmartSDR for Windows, SmartSDR for Maestro, SmartSDR for M models, SmartSDR CAT and DAX. Please download and review the SmartSDR v3.1.7 Release Notes prior to installing SmartSDR v3.1.7.
SmartSDR v2.6.0 can be downloaded from the FlexRadio Systems website. SmartSDR v2.6.0 is a maintenance release containing software fixes for version 2 of SmartSDR for Windows, SmartSDR for Maestro, SmartSDR for M models, SmartSDR CAT and DAX. Please download and review the SmartSDR v2.6.0 Release Notes prior to installing SmartSDR v2.6.0.
SmartSDR v1.12.1 can be downloaded from the FlexRadio Systems website. SmartSDR v1.12.1 is a maintenance release containing software fixes for version 1 of SmartSDR for Windows, SmartSDR for Maestro, SmartSDR CAT and DAX. Please download and review the SmartSDR v1.12.1 Release Notes prior to installing SmartSDR v1.12.1.
A software license for the FLEX-6000 is required to run SmartSDR v3.x and SmartSDR v2.x.
If prompted to upgrade your SmartSDR license, obtaining and validating a license for your FLEX-6000 software defined radio is a simple process. Once the radio and client have network access to the Internet, just load any version of the SmartSDR v3.x software on your PC or Maestro. In the radio chooser, if a radio requires a license, a status message will indicate a license is required before connecting to the radio and updating the firmware. A “Buy” button is also presented so that you can conveniently purchase a SmartSDR v3.x license (which is inclusive of v2.x) using our Online Store. Please see details below regarding purchasing a SmartSDR software license for your radio.
The following highlights are SmartSDR specific items:
SmartSDR v3.1.7
How to install SmartSDR v3: https://youtu.be/zO90kVkIYM8
Introduction to SmartSDR v3 and multiFLEX: https://youtu.be/e-vNsepxOzg
For information on compatible third-party applications, visit our Works with FLEX web page (https://www.flexradio.com/works-with-flex/).
The cumulative SmartSDR v3.1.7, v2.6.0 and v1.12.1 ChangeLog detail is listed below.
________________________________________
V3.1.7 General Release 2019-09-17
Documentation updates
#3709 Added SmartControl for Maestro and M Model radios
#6873 DAX: Fixed issue where DAX audio devices would get scrambled and not work properly after a Windows Update
#5203 DAX: Sound devices are now prevented from being selected as default sound device
#7543 DAX: RX Gain levels are now correct when starting SmartSDR after DAX has been started
#7572 DAX: Channel 8 RX meter now works properly (6700 only)
#7668 Fixed MON/FDX interaction that caused FDX to not work when the monitor was enabled
#7573 SSDR: Radio auto-connect on startup now works properly
#7520 Maestro: Automatic SmartLink login on startup now works properly for Wifi connections and delayed Internet connections relative to power-on
#7472 SmartSDR and Maestro remote audio (PC Audio) now stream with lower bandwidth (compressed audio) for easier use on VPNs and low performing LAN networks
#7473 Fixed issue where TUNE/MOX would be disabled when the TX Slice is on 2m and XVTR
#7637 EQ RX/TX Checkboxes can no longer both be unchecked
#7049 SSDR: MIC and Transmit Profile dropdowns can now be scrolled through with the mouse scroll wheel
#5491 Right-most pixel of Panadapter no longer appears elevated
#7666 The hit area of Slice audio balance was improved
#7484 multiFLEX: Connected stations are shown in the Radio Chooser, even when there is only one connected station
#7554 M-Model: radio screen now shows connected multiFLEX clients, even when there's only one
#7532 Maestro/M: License refresh button now shows refresh status and updates UI after completion
#6860 M models are now properly indicated in the SmartSDR for Windows Radio Tab
#7108 6400/6600/M: Modified fan speed behavior on boot up to address false-positive fan errors
#7675 Fixed sporadic popping and interruptions in RX/TX Audio due to clock settings
#7500 TURF: Changed IARU1 6m 50.0 to 52.0 per current allocation
#7567 Added 9k tune step to AM modes
#6756 Zoom-to-segment: the "S" indicator is now displayed correctly after a band change
#7497 Closing a Diversity Slice now properly re-centers Slice audio pan control
#7544 SSDR: multiFLEX dashboard is no longer resizable, which prevents accidentally hidden controls
#6787 API: Added proper response messages to several ATU commands
#7626 API: Removed Slice::PlayEnabled setter since it comes from radio
V2.6.0 General Release 2019-09-17
V1.12.1 General Release 2019-09-17
SmartSDR v3.1.7
- New SmartControl Mode for Maestro: SmartControl is a new feature for the Maestro that allows the operator use the control surface (knobs and buttons) of a Maestro to control a FLEX-6000 while using SmartSDR for Windows or the front panel of an “M” model radio at the same time, for added operating flexibility. (#3709)
- Updated DAX Drivers: SmartSDR v3.1.7 includes an updated DAX driver that should not scramble the device names after Win10 updates. In addition, the DAX drivers are not candidates for the Windows default sound devices when other sound devices are available. This prevents the default sound devices from changing. (#6873, #5203)
- Expanded functionality of Remote Monitoring on Phone Modes: The multiFLEX monitor functionality is enhanced to provide an ability to listen to the other connected client while transmitting and using the Monitor feature. It is possible to hear the remote and local audio mixed in the Monitor. The initial release of this feature is for phone modes only, remote CW sidetone is currently unavailable. (#7344)
- Lower Bandwidth Usage for VPN Connections: SmartSDR and Maestro remote audio (PC Audio) now stream using lower bandwidth (compressed audio) for improved performance on VPNs and lower throughput LAN networks. (#7472)
- Enhanced multiFLEX Connection Information: Enhancements to multiFLEX including improved notifications of connected users. (#7484, #7554)
- Bug Fixes: Additional bug fixes since v3.0.27. Please refer to the SmartSDR V3 ChangeLog for a complete listing.
- Updated DAX Drivers: SmartSDR v2.6.0 includes an updated DAX driver that should not scramble the device names after Win10 updates. In addition, the DAX drivers are not candidates for the Windows default sound devices when other sound devices are available. This prevents the default sound devices from changing. (#6873, #5203)
- Bug Fixes: There are other bug fixes in this release since v2.5.1. Please refer to the SmartSDR v2.5+ ChangeLog for a complete listing.
- Updated DAX Drivers: SmartSDR v1.12.1 includes an updated DAX driver that should not scramble the device names after Win10 updates. In addition, the DAX drivers are not candidates for the Windows default sound devices when other sound devices are available. This prevents the default sound devices from changing. (#6873, #5203)
- Bug Fixes: There are other bug fixes in this release since v1.11.12. Please refer to the SmartSDR v1 ChangeLog for a complete listing.
3
- 683 The Flea Market
