Logging with Maestro
Frank W2YK
My logging program works fine with my 6400/SmartSDR. However, can't get it to work when using Maestro. I know the communication path with the 6400 is different from Maestro to SmartSDR. Is there something I'm missing, or how can I get a logging program to work with the Maestro/6400 combo. Using DX4WIN logger, plus have HRD..
Thanks,
Frank W2YK
Thanks,
Frank W2YK
Frank, You simply start SmartCAT on your logging computer and in the drop down select the Maestro instead of SSDR. It will work beautifully. 73,,, Mack W4AX Alpha Team1
Amazing, just tried it and works perfectly!!!
Thanks, Frank
Hola chicos , a mi se me queda el dx4win con la ultima frecuencia de apagado ....tengo que apagar flex y dx4win para que se pongan bien0
