Routine 6500 Checkout
Lawrence Gray
I recently sent my 6500 in for a routine checkout and updating as required. The Flex folks turned my radio around quickly. The PA fans were also replaced at no extra charge.
Great service--thanks,
Larry W1IZZ
Larry W1IZZ
Updating? What would that be? Do all 6500's need to have their PA fans replaced or just some serial numbers?
Thanks and 73,
Bob
Yes. I would also like to know what updating. You can easily update software yourself. Was this a hardware update? Were you experiencing any issues? Best 73, Jim0
Of course I can update the software myself--been doing it for years. I just sent it in to be checked and updated if there were any hardware updates. There weren't any updates. I've had the 6500 for a long time, used it a lot, and just wanted checked out. The post was to give some praise to the Flex folks for the excellent turnaround. Apparently, I should have just sent a letter to Flex, instead of posting here.0
The nice thing about SDR is 99% of the time updates are in firmware and software with the hardware being stable. When I purchased the 6500 years ago it was already rung-out and no h/w updates required. in the good old era of vacuum tubes rigs required annual alignment. Solid state rigs were better with much less alignment requirements. The Flex 6x00 series self-calibrates at power up; just can't bet it....
k3Tim
Lawrence, I did not mean to offend you. I was curious if there were any hardware updates. It was good of you to compliment Flex here. 73, Jim.0
Tim,
I totally agree. I just wanted confirmation that my 6500 was working to spec's. Since I no longer have access to the level of equipment needed to properly test the 6500, I wanted to have confirmation from the folks who designed and built it. I received that confirmation quickly at a very reasonable cost, along with very prompt answers to my questions. Great support, in my view.
It is a great reminder that periodically perhaps we all should have our gear checked out.
Sometimes I think it would be useful to have a Hobbs Meter on important gear (an in-use hours measuring meter) and schedule inspections & PM (preventive maintenance) base on accumulated Hobbs hours.
But then would we ignore it when a service interval comes up?
Steve
K9ZW
Blog: http://k9zw.wordpress.com
Larry
Like your idea of PM. Good investment. My 6500 has been running 24/7 for >4 years with no problems, luckily. My PGXL did need a little TLC and the service was fantastic Glad you posted your positive comments.
Bernie
W7DMC
Amen, brother.0
Thanks for the post! I’v had mine now for a long time. I think it is time I opened it up and to clean it out and check fans, heat sinks etc. that collect dirt and dust. Your post has acted as a reminder for me.....thanks!0
