Maestro - How do you cancel a Function Key?
Steven WA8Y
Steven WA8Y Member ✭✭
edited February 2020 in Maestro
I press the wrong Function key (sending cw).  I accidentally made it send more instead of stopping.  I eventually taped the Menu and I think that is what stopped the sending.
What is the correct way to stop a Function Key from send the CW message?
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    edited August 2019
    Hammer the keyboard Esc key.    That should do the trick Steven.
    Regards
    Lar  K1UO
  • Duane_AC5AA
    Duane_AC5AA Member ✭✭✭
    edited August 2019
    Don't think that helps when the Maestro button has been pushed since SSDR is most likely not running.  I don't know the answer, but would like to!
  • K1UO Larry
    edited August 2019
    Ah...  you must mean the Maestro function keys set up for cw macros.   I was indeed thinking of CWX in.SSDR.     I remember doing the same thing occasionally when trying to use the Maestro cw macros but never did find an "Esc" from those.
  • Sherman Banks
    Sherman Banks Member ✭✭
    I don't have my buttons set up for CW memories but try tapping one of the iambic paddles while the message is sending.
  • N0EG
    N0EG Member ✭✭
    edited January 2020
    is there a consensus that there is no way to stop sending cw if you initiate via a function key?
  • Duane_AC5AA
    edited January 2020
    I haven't tried that yet, but suspect if the key is connected to the Flex, not the Maestro, it may not help.  (This is how I'm configured.)  I plan to check it out, however.
  • Duane_AC5AA
    Doesn't stop the F-key sending tapping the key plugged into the 6600.  Haven't tried it plugged into the Maestro.
