SliceMaster and SSDR 2.5.1
N6WT Kent
N6WT Kent Member ✭✭
edited August 2019 in SmartSDR for Windows
I was able to install SSDR 2.5.1. The only problem I am having is with SliceMaster.  When CWSkimmer starts it is not on the same frequency as the radio. If I click in SSDR waterfall CWSkimmer does not follow. If I click int the CWSkimmer waterfall the radio will change to the frequency clicked.
I see there was a problem with SM and SSDR v3 and there is a fix coming, is there a problem with 2.5.1 that I did not hear about??
Using SliceMaster v0.10.7b
Kent
N6WT
