Dax problem? no sound on wsjtx on local PC
Ben van Schoor
Member ✭
Hello, im using a few months wsjtx without any problem, yesterday my local computer crashed and place a new one with the latest windows 10. now wsjtx has no sound, settings are oke because a make pictures one week ago and everything is working exept the sound.
i have now audio RX and TX on the DAX screen looks good, blue and i see the red signal lin e bud wsjts dont see.
when i go to Windows configuration/sound i see the sound on DAX audio RESERVED RX 1 and not on my choice oif wsjtx DAX audi RX1.
this is all on the local network
pls help me ?
i think it,s the new windows, how can i repair?
When i use other remote PC via internet without updates it s no problem
can someone help me remote ?
PA3BVS Ben
pls help me ?
PA3BVS Ben
There are many threads on the Community providing solutions to DAX audio issues. See the following thread: https://community.flexradio.com/flexradio/topics/most-common-fix-for-dax-driver-errors-in-windows-spring-update-1803-you-can-do-this Failing that, put in a HelpDesk ticket.0
Just had this problem last night. Win 10 Sound manager showed playback the TX 1 and Dax Rx 1. Record showed Dax Rx1. I had no Tx audio in my Dax window. Received look fine but wasn't able to change the level seen in the sound manager. Nothing was decoding. After checking, adjusting and charging settings in DAX, Slice A Dax 1, DAX Audio, etc, and closing and opening WSJT-X, check radio and audio setting in WSJT-X, opening and closing SMARTSDR it started decoding. Still no TX audio. Then WSJT-X thought it was still open, I couldn't actually open or use it so I shut down the Fkex 6600, SmartSDR and rebooted the PC. Started up the Flex, SmartSDR, WSJT-X and everything worked it even populated VK9APX in the TX boxes. That's why I was using WSJT-X F/H last night, I was trying to hear/ work Norfolk Island last night.0
- 105 Aurora
- 974 Genius Products
