Flex 3000 SDR not talking to Radio
Dana L. Barre
flex 3000 not working with software . Did work upon Download of software upgrade but not now. Using windows 7. have uninstalled numerous times and even reinstalled windows 7. No luck Would like to try an older SDR software but don't know where or how to download. Any suggestions
Dana,
The default firewire driver in Win7 is broken, so make sure you go to the device item in the Device Manager and change the driver to the 'Legacy' driver. That might help!
https://www.flexradio.com/downloads/
Go to support then Downloads then Discontinued
under PowerSDR and down load the .exe and the Release notes file for version 2.7.2
make sure you see the radio under the FLEX Firewire driver.
Not sure if this version will work any longer if you did the firmware update for the NON-Flex PowerSDR version
Hope you can get it going
Bret
It has nothing to do with PSDR version.
As Neil pointed out, Check the fire wire driver,,it should be Lagacy. Or make sure you have the correct driver for your Fire Wire Card,,Win 70
- 715 The Flea Market
- 218 SmartSDR+
- 469 SmartSDR for Mac
- 130 Aurora
- 994 Genius Products
- 363 Tuner Genius XL
- 138 Antenna Genius
- 331 Shack Infrastructure
- 235 Networking
