Suddenly, No Power Output (CW, FT8, RTTY)
kg5udale .
kg5udale . Member
edited July 2019 in SmartSDR CAT
I'm using a Flex-6600M, FLDIGI, SmartSDR DAX and CAT, N1MM+, and Windows 10. All using the latest versions.
During last weekend's NAQP RTTY, I twice experienced no power output during transmit.  Both events were on the same sliceA. On the first event, I tried restarting DAX, CAT, N1MM, FLDIGI. Restarting each netted 0 watts out. I rebooted the radio. Back to full (65w) power.
A few hours later, I got 0 watts again. This time, I tried just changing the slice to another band then back to the original band. That seemed to work.
I've had 0 watts happen once in FT8 mode and and once in CW mode a few weeks ago, too. But, I think back then I just shut everything down and restarted the PC.
Can anyone offer any insight why this may be happening? I'd hate to have to re-organize the desk to put the wattmeters right in front of my face.
  • Ray Gustafson WB0HHM
    edited July 2019
    I am having same issue , but haven’t tried your method for getting it back , I turned 6600 off and back on To get back , will try opening another slice next time
  • Eric Gruff
    Eric Gruff Member ✭✭
    edited July 2019
    I had the same problem when changing bands. I had reload the generic SO2R profile, then fiddle with the settings to get back to RTTY and then save it as SO2R_RTTY (just my name for a different SO2R profile). It happened more than once and both on the Maestro and SSDR. It's clearly a bug in the radio control, but I could not figure out where.
    I checked all settings - power out, tune power out, TX filters (very obvious for RTTY), etc. All seemed fine.
    I know this isn't terribly helpful for diagnosis, but I wanted Flex to know it's not just you. I spent about 30-45 minutes getting a once-working setup back online for the contest.
