Under M1NN+ the headphones must be plugged into the radio to monitor function keys, however DAX bein
Stan VA7NF
Stan VA7NF Member ✭✭✭
edited July 2019 in DAX
Opening apologies, I'm a CW man looking at a club 6600 V3 SSB.
If headset plugged into Maestro I cannot monitor N1MM+ voice keyer but when plugged into 6600 the mic input is muted when DAX is on.
But turn DAX off then N1MM+ voice keyer does not work.
Also noted, when mic plugged into Maestro and speaker plugged into 6600 the mic is not muted but only when keyed from Maestro PTT.
What configuration permits monitored N1MM+ macros and mic voice on PTT?
  • k0eoo
    k0eoo Member ✭✭✭
    edited July 2019
    Stan, I don't see where you say you pushed the MON button on the Flex MIC setup panel?  You cannot monitor CW tone or voice without pushing that button and adjusting the AF gain slider next to the button.
