SSDR iOS with Spectrum internet and Smartlink
Burch - K4QXX
I have an issue using SSDR iOS on my iPhone with Spectrum internet. I can connect via Smartlink and it will run fine for about 5 minutes. Then the audio and panadapter will just stop. If I hit the disconnect button and then reconnect, everything works fine for another 5 minutes and then it will stop again. I have tried 4 different locations in the Tampabay area that have Spectrum and it does the same thing at all locations. I work in IT and I have my own Spectrum internet connection in my office. I am the only one who uses it. It's 100 down, 10 up and it runs SSDR iOS perfect.....for 5 minutes. If I use my Maestro, Windows SSDR or DogparkSDR on my Mac, everything works perfect. It is only when I use the iOS SSDR app. Does anyone have any idea what could be causing this? I am working in our Sarasota office today that uses Comcast for internet and the iOS app runs fine.
This Spectrum issue only occurs when using Smartlink. If I connect my phone to my vpn and then run SSDR iOS, everything works fine. That is my workaround right now so it's not really a big deal but I'd really like to figure out what is causing this.
Burch
K4QXX
Burch
K4QXX
I might be switching to Spectrum, were you able to fix this issue?0
No. I still have the issue. iOS unusable in this area via Smartlink remote using Spectrum as the remote wifi connection. Works for 4-5 minutes and then just freezes. Works fine on SSDR and Dogpark. iOS works fine via a VPN connection. Just can't use Smartlink.
Having the same problem.
So I put this VPN on my phone?0
- 715 The Flea Market
- 216 SmartSDR+
- 469 SmartSDR for Mac
- 130 Aurora
- 993 Genius Products
- 138 Antenna Genius
- 331 Shack Infrastructure
- 235 Networking
