Odd behavior on my 6400M start up?
wa4wab
wa4wab Member ✭✭
edited April 2020 in FLEX-6000 Signature Series
Often I have ssdr loaded/waiting for the radio to be started. When startup the 6400m it is about a 40% chance the radio will go directly into the radio display panial, I then have to "disconnect" the radio so I can run it via my PC. And yes the "auto startup" is disabled. This was very rare with 2.x but more prone with v3.x. Has any other members seen this?
  • Andy W3LI
    Andy W3LI Member ✭✭
    edited April 2020
    To date I have never had a problem with SSDR and my 6400M. I boot the pc first and then double click on the SSDR icon on my desk top. That sequence has always worked.
    Andy...W3LI
  • wa4wab
    wa4wab Member ✭✭
    edited June 2019
    "To date I have never had a problem with SSDR and my 6400M. I boot the pc first and then double click on the SSDR icon on my desk top. That sequence has always worked."
    That is also the way I start up my 6400M but with  results I posted above.
  • N8MAS
    N8MAS Member
    edited June 2019
    Im having the same issue with my 6400. After startup of my computer, flex is on with green light illuminated, I double click SDR icon, the DAX and CAT open and I get the connect box. I click connect, the box goes away, no display of radio on screen but its in my task manager as running. I have to close it in task manager or disconnect the radio from the computer then it works fine
