What am I doing wrong??
N9VC
N9VC Member ✭✭
I calibrated and the 6700 does what it supposed to do. But the display makes it look
50 Hz off after calibration. Not sure if I am seeing what I should be seeing. I believe
I am doing the calibration right, but need to have someone more knowledgeable than
I to verify.
73, Jim N9VC
  • Ed, K0KC
    Ed, K0KC Member ✭✭
    edited June 2019
    Jim,
    Are you on 2 meters? If so, there is a calibration problem that has not been resolved by Flex. If on lower frequencies and using Antenna 1 (SCU 1), is your WWV (or CHU) signal strong?
    Whoops...just saw your attachment!
