power genius xl and vertical antenna
Richard Zalewski
Will the power genius be able to handle an all band un-tuned vertical? My current SO2R config uses a Zero-five vertical. When using this antenna I must use low power and the 6600M tuner or use the tuner in my amp. Since I read that there is a tuner coming my guess is the answer to my question is NO.
Odds are, your guess is correct. According to the PG-XL User Guide output power maximum SWR allowed is 1:3. And power output will be reduced when SWR exceeds 1:1.5.
As for the 4o3A Auto-Tuner, I've yet to see any specs on this device.
The answer is no. In fact, the tuner designed for the amp has a rather limited range so even with it you will probably have issues with an untuned vertical.0
- 105 Aurora
- 974 Genius Products
