Maestro does not turn on my 2MLDPA
Mike Presnell
I have a 6700 using 3.0.19 and a DEMI 2MLDPA. When I open Smart SDR the LDPA is turned on, however when I use the Maestro it does not. PTT is working from the Maestro to the 6700, however nothing from the LDPA. Checking the settings inside the Maestro, everything appears the same as the settings in SmartSDR, ie. USB cable, etc. Is this a known issue? Any recommendations? Thanks in advance for your thoughts/ideas. r/Mike WB0O
- 692 The Flea Market
- 119 Aurora
