Change Flex 6400M Tuning Step Size With Function Keys
tmcdonough
tmcdonough Member
edited December 2019 in FLEX-6000 Signature Series
Is there a way to program the function keys to make it easy to toggle between two different step tuning settings? I'd like to be able to quickly move back and forth between a big step when scanning the band and a small step for tuning in a station.
I nearly always use the front panel controls and not the remote software.
SW Version 3.0.19.46
  • Ted  VE3TRQ
    Ted VE3TRQ Member ✭✭✭
    The choices available for the macros is limited. Looks like the closest you can get is segment or band zoom :-(
  • Tim N9PUZ
    Tim N9PUZ Member ✭✭
    edited September 2019
    We can always hope! It'd be nice if there was a way to just record a series of key presses and store them to one of the function macros.
    I know if you hold the "step" button down for a long press the value changes the other direction. I always seem to forget that in the heat of battle!
    Tim N9PUZ
  • Mark Gottlieb
    Mark Gottlieb Member
    edited August 2019
    My questions is...Where is the "step" button?  I am searching all the menus but must be blind to it.
    Mark KK2L
  • Mark Gottlieb
    edited August 2019
    I found it on another community discussion string!
    Mark
    KK2L
