N1MM DVK remote - anyone have it working?
Steve Bunting
Steve Bunting Member ✭✭
I am a long time smart link user and have enjoyed cw contesting using N1MM. I am going to try a remote SSB contest but want to use N1MM to plat wav file CQs.
I know how to set up N1MM/SSDR to play wav files when I am in front of the radio and have a mic plugged into the rig itself. I cannot work out how to do this with a mic plugged into a remote PC as AFAIK I would have to be forever toggling DAX/sound card inputs. Has anyone solved this?
Thanks!
Steve M0BPQ
  • WX7Y
    WX7Y Member ✭✭✭✭
    Yes this is a problem I have had for over 1.5 years since I went full remote, PAIN IN THE NECK for sure having to switch the DAX button back and forth.
    Hope this is on the fix-it list.
    If you find any workaround please let us know.
    Bret
  • Larry _ NY8T
    Larry _ NY8T Member ✭✭✭
    edited April 2019
    FRLogger has a nice audio feature that will turn dax on when you play one of your wav files and turns dax back off when its done.
  • Steve Bunting
    edited April 2019
    Thanks for replies so far. If FRlog can do it then there must be a cat command that can toggle DAX. I wonder what that is and if we could get it added to N1MM.
