Trying to get iPhone to transmit SSb Need help no output power all though mic level meter respond
Pat
Pat Member
edited April 2019 in FLEX-6000 Signature Series
Trying to get iPhone to work, I connect up thru smartlink, all appears to be good, I have almost everything working, but when I key the mic, I have no output, the mic level shows it going forward to -10 or so, but no output at all. The tax inhibit is not on. If I use the tune I get full carrier output, but no effort out with audio, I have tripled checked my setting. If I use the 6500 with out smartlink everything works perfect????? Need help !
  • Pat
    Pat Member
    edited April 2019
    Problem solved. I contacted Marcus with the problem, he told me that I can NOT use smartlink on my own network, that I have to access it thru the internet for it to work. Which I followed his advice and is now working if I don’t use my network that 6500 is connected to. He states if I want to use the iPad I must use the old program, not V3 . It works as he stated. Ka1cde
