Can't finish update to refresh licence but getting "Radio Internet: None!"
Ed Garrison
Problem updating radio to V3. Wants to connect to internet to complete licensing.
have flex hard wired to router port.
Tried bypassing router, no change.
What am I not doing correctly.
Thank You
Ed K1EDG
Pop out box shows:
Serial: 3818-0512-6400-1032,
Max Licensed Version: v2,
Radio ID: 00-1C-2D-05-0A-96,
Radio IP: 169.254.4.156,
Radio Firmware: v3.0.19.119have flex hard wired to router port.
Thank You
Ed K1EDG
Ed,
The message about needing to connect the radio to the internet shows up when the radio doesn't think it has internet access. The IP address starting with 169.x says that the radio currently believes it is in a link local (direct connect) state. If you change the network connection, you'll need to reboot the radio for the changes to take effect in the radio.
Once you have purchased a license, if you plug the radio back into the router and reboot, I suspect this will take care of the internet message.0 -
Tu Resulved ! ....73 Ed1
I have the same problem!!0
Christian, how do you have the radio connected to the network?0
I have a laptop connected to internet via WiFi and radio is connected to the laptop via an Ethernet cable0
Since your radio is not direct connected to your network, you should bridge your WiFi network to your wired port on you laptop. Used this procedure that’s posted in the Helpdesk help section. https://helpdesk.flexradio.com/hc/en-us/articles/115003741486-Enabling-Network-Bridging-for-Link-Local-direct-connected-FLEX-6000s Once you have the bridge setup, don’t forget to remove the DC from the radio, so it can retrieve an IP address. Let us know how you are doing. Dudley WA5QPZ2
The bridge was the solution, thank you very much0
- 110 Aurora
- 322 Shack Infrastructure
- 227 Networking
