Connectivity to Smartlink via remote Iphone
Working with 6400 and Maestro V 2.49, all functions OK both in shack and away with WiFi
When using iPhone in the shack with WiFi, connects both on local via Smartlink without problem.
When using iPad (WiFi only) in the shack with WiFi, connects both on local via Smartlink without problem.
When using iPhone remotely with WiFi, connects via Smartlink without problem
When using iPhone remotely via phone data, will not connect via Smartlink
When using iPad remotely using WiFi from the iPhone as a portable hotspot, connects via Smartlink without problem
So there is plenty of data and super fast access via 4G EE on the iPhone and this is proven with the hotspot/Ipad connection.
So the BIG question - why no iPhone connection on its own data ?
I hope all the above clearly explains the options tried !
73 Phil G4UDU
73 Phil G4UDU
Have you enabled IPv6 in the the app? Are you on T-Mobile? Marcus addresses these issues in his manual.
Thank you - enabling IPv6 fixed it.
I overlooked it !
Many thanks
73 Phil
- 690 The Flea Market
- 112 Aurora
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
