CX-Auto, Palstar AT-Auto and Flex 6XXX
Dan KG0AQ
Does anyone have experience with the Palstar AT-Auto using the CX-Auto antenna switcher?
I am using the AT-Auto with DDutil now and it works great. There is a setup for the CX-Auto in DDutil. I am not sure how it will control all 8 antenna ports and how the Flex can control any of it..If anyone has this combo I would appreciate your input.
Thank you,
Dan KG0AQ
Thank you,
Dan KG0AQ
I only have limited experience with Palstar HF-Auto... ddutil and Automatic Band Following should select the correct antenna on the CX-Auto for the band selected... http://k5fr.com/DDUtilV3wiki/index.php?title=CX-Auto Pressing Tune on the radio will instruct the Palstar HF-Auto to recall tune memory or Tune manually against the Antenna connected.
From all indications the Palstar AT-Auto is the same as the Kessler AT-Auto so likely the same warning/configuration is required... DO NOT USE AUTOMATIC BAND FOLLOWING...- See the CX-Auto owners manual for setting up the AT-Auto tuner to control the CX-Auto antenna switch.
- Pay particular attention to operating manual section 1.3.2.11, configuring the CI-V Tx Enable internal jumper. It must be shorted or the AT-Auto will not control the CX-Auto switch.
http://kd0zv.com/palstar-at-auto-vs-palstar-hf-auto/
0 - See the CX-Auto owners manual for setting up the AT-Auto tuner to control the CX-Auto antenna switch.
