error opening dax audio
Ken Golubski
It seems I cannot get DM 780 working with my 6600. I have HRD and the logbook running FB, but every time I try to run DM 780, it tells me:
Error Opening DAX Audio RX1
Sound Card I/O: Failed at 48khz and 8khz, giving up.
Reading several of the previous posts here, it seems like the only solution for similar problems is to reinstall the drivers. Is that the only solution? This is all a brand new install, with no updates. Windows 10.
I would open the sound control panel and look at the names of the Flex audio devices. The name of the device should match the description of the devices in parentheses. If they do not, Windows update has likely destroyed your devices. The sound control panel can be reached conveniently by right clicking on the speaker icon in the tray, and selecting the sound control there. I’m a Mac guy, but occasionally use Windows, so I am not the best choice to fix theses issues., There are a number of threads on the community discussing this.0
Yes, all of the names match. I can see the audio on the DAX Control panel graphic.
Have you seen this article, Ken? https://helpdesk.flexradio.com/hc/en-us/articles/202422549-SmartSDR-Ham-Radio-Deluxe-DM780-HowTo-Setup-Guide0
Thanks, Ted. I sure did. Mine is set up exactly as he describes. I just can't get past the error when loading DM 780.
- 409 Community Topics
- 707 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 367 FLEX-8000 Signature Series
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
