No TX waterfall or PWR indication using Transverters :(
Hugh - VA3TO
Hugh - VA3TO Member ✭✭
edited March 2019 in New Ideas
I sure wish SmartSDR could display at least one or the other (both would be nice) of the TX waterfall and/or Power indication when using the transverter port.  I'm guessing this is a hardware limitation... TX monitoring likely comes from the directional coupler after the P.A. and the Transverter port taps TX off in an earlier stage !?
0 votes
In Review · Last Updated
  • Mack
    Mack Member ✭✭✭
    edited March 2019
    Hugh,
    You are correct. The FlexRadio has no way to measure an external transverter nor does any other radio unless there is built in integration between the radio and transverter.
    Mack
    W4AX
    Alpha Team
  • Marc Lalonde
    Marc Lalonde Member ✭✭
    edited March 2019
    still not a valid argument for not show power send on XVRT port
    i knot on my system that +10dbm ( max set on mt setting)  on XVRT = 1KW output
    so usually i may knot that 100% power = 1KW  if all working good ..
  • Hugh - VA3TO
    edited August 2019
    Flex should add a means of measuring the low level power for it's future designs. They have inexpensive
    chips for this now you know ;)
