Stuttering on iPad and MacBook Pro Resolved
Richard Everett
Richard Everett Member ✭✭
edited February 2019 in FLEX-6000 Signature Series
I took the advice of others regarding the stuttering of SmartSDR on my iPad and MacBook Pro by making the recommended adjustments to my WIFi network, reduced FPS and Rate of screen refreshment and nothing worked....that is until I halted Location Services on both.  Now, it runs smoothly and I can even push up the FPS and Rate to as high of a setting that I would like without affecting performance.  It is such a relief to finally get to this point.
  • Joe N3HEE
    Joe N3HEE Member ✭✭
    You will also find that turning off bluetooth on your iPAD will greately reduce audio drop outs.
  • Rick - W5FCX
    Rick - W5FCX Member ✭✭
    Thanks for sharing that! This has been issue for years.
  • Craig Williams
    Craig Williams Member ✭✭
    That made stuttering better on my iPad 2018 but did not completely cure it. Multi tasking has always been a low priority with Apple. My best remote operation is with a netbook and my ATT wireless access point.
