Solid Orange color with On/Off Sw when turned off
Tom W3FRG
Tom W3FRG Member ✭✭
The On/Off switch flashes green during shut down then turns solid orange when unit shuts down.
Starts up normal with no other codes present.
  • David Decoons, wo2x
    Sure it isn’t yellow?
    Here’s the color codes
    https://community.flexradio.com/flexr... I have seen it yellow if you inadvertantly enable the GPSDO option in software, whether or not the radio has one. Dave wo2x
  • Craig_KØCF
    Craig_KØCF Member ✭✭✭
    edited April 2019
    Do you have the GPSDO installed? If so, solid "Amber" after shutdown means the Radio is off, but the GPS is powered for stability.
  • Tom W3FRG
    Tom W3FRG Member ✭✭
    edited February 2019
    Hi Dave,
    You are correct. It was Amber and I checked the Uninstall GPS ands its now gone, back to normal, Off.
    I checked the color code errors and don't see one of Amber after the unit is turned off.
    Regards,
    Tom W3FRG
  • Tom W3FRG
    Tom W3FRG Member ✭✭
    Makes sense.
    But it appears the unit is powered w/o a GPS as long as the 13.8Vdc is applied, which I assume supplies the freq std to maintain stability rather than a cold start.
    73  Tom W3FRG
  • Tom W3FRG
    Tom W3FRG Member ✭✭
    Its interesting that the color code error list that I referenced in the User Manual is quite different than the list in the Hardware Manual; The list you supplied.
    It is listed as Yellow in the list Tim provided. 73 Dave wo2x
