Adjusting sliders in DAX
KI4P
Only had my 6400 a week and still learning, I have fl digi working, I was used to adjusting alc on 590 but wonder if I have too much or maybe too little using Dax. See in instructions that sliders should be less than 0, so as close to 0 is ok? Also on audio to fl digi have sliders all way over too right and don’t see the typical blue waterfall in fl digi, see signals, trying to make sure I have alc and audio to program set right, thanks for reading and any input.
Try clicking with mouse pointer just to the left of the dot slider to go down one point or just to the right of the dot slider to go up one point. It works nicely to micro adjust any slider,
Keith
W7ZAC
Thank you Keith I guess my main concern is greeting to much on tx audio, and understanding the sliders0
Read this post, it should give you the info your looking for.
https://community.flexradio.com/flexradio/topics/ft8-and-alc-on-6500
Thanks helped tremendously!0
