slice master
Don w2xb
Have quick question about slice master.When opening software I get a double trace in the cw skimmer. Have to switch to "wdm" to get the single trace. Have do this for every band change or open the software. Is there a way to keep it at wdm?
Don...w2xb
P.S. using windows 10
Don...w2xb
Don,
Slice Master always chooses MME. What you are seeing indicates that your DAX driver installation is having trouble. I'd suggest going through the fix-up procedure and giving it another try.
--Don
Don W2XB , I'm having the same problem using windows 10 and MME drivers with CWSkimmer . Like you WDM work ok . I went back to my windows 7 computer and MME work great !
Please let me know if you find a fix with ur W10 , Skimmer and MME
Thanks Ed N5DG0
- 684 The Flea Market
