6500 control using DDUtil to Ardino (Teensy)
Ron K2RAS
Ron K2RAS Member ✭✭
edited January 2019 in FLEX-6000 Signature Series
I would appreciate any direction on my serial connection to the Flex6500.  I have an Arduino-based Mag Loop tuner connected to the Flex using an FTDI serial adapter.  The Arduino is receiving frequency info but will not PTT the flex for tuning.
DDUtil has the serial port setup in RPT1 (Repeater 1 will not pass data).  The DDUtil serial monitor displays the following.
(When the radio frequency is changed)
13:18:24 [RCP1 READ] IF;
13:18:24 [RCP1 WRITE] IF000142379400010+0000000000030000000;
13:18:24 [RCP1 WRITE] FA00014237950;
13:18:24 [RCP1 WRITE] FB;
13:18:25 [RCP1 READ] IF;
(When a tune initiate is sent from the Arduino)
13:19:22 [RCP1 READ] IF;
13:19:22 [RCP1 READ] PC;
13:19:23 [RCP1 READ] RX;
13:19:23 [RCP1 READ] MD0;
13:19:24 [RCP1 READ] PC000;
13:19:24 [RCP1 READ] IF;
I am almost there but don't know whether the problem is with the DDUtil setup, or the PTT commands being sent by the Arduino.  Thanks much.
Ron/K2RAS
