Switching between digital audio source and voice audio
Tim K9WX
Tim K9WX ✭✭✭
edited March 2020 in SmartSDR for Windows
Something changed in the way microphone VOX and DAX work together on SSB between SSDR 2.3.9 and 2.4.9 with my 6600 and I have been unable to get them to work together in 2.4.9.  I don’t see anything in the release notes that would explain this change.
Section 20.3 of the SSDR Software User's Guide says, in part, "If the DAX button . . . has been selected and PTT is initiated through CAT, audio will be used from the DAX source rather than the currently selected microphone input. If, however, a microphone PTT is depressed, the selected microphone will be used for input. This allows the operator to switch between a digital audio source and voice audio quickly."
I found this to work as described in SSDR 2.3.9.  I found it would work whether I used a footswitch with the mic for PTT or used VOX.
I don't work a lot of phone: my last phone QSO was back in August when 2.3.9 was the most recent release.  This evening, with SSDR 2.4.9 installed, I find that VOX and the mic will no longer key the radio if the DAX button has been selected.  I must manually turn DAX off in SSDR in order to use VOX with the mic.  The footswitch with the mic still works with DAX turned on.
I downgraded to 2.3.9 to make sure I was not imagining things and found the behavior as I remembered it: that I could have both mic VOX and DAX turned on at the same time, allowing me to seamlessly go back and forth between voice audio and digital audio without using a footswitch.  I then reverted to 2.4.9 and found once again that I had to choose between using VOX with the mic or using DAX.  The footswitch will allow me to use the mic just fine with 2.4.9, but the ability to use microphone VOX alongside DAX is not there.
Here are some screen shots showing my setup.  The first one is 2.3.9, both VOX and DAX are selected and both work.
This second image is from 2.4.9.  Both VOX and DAX are selected but only DAX will work.  If I want to transmit mic audio I cannot use VOX.  I either have to turn DAX off or use the footswitch.
The settings in these two images appear identical to me.  But perhaps I am missing something.  Any suggestions would be appreciated.
I should note that I am using an N1MM+ 1.0.7342 macro to provide the digital audio for the radio with both 2.3.9 and 2.4.9, and everything is configured for SO2R.  The result is the same regardless of which slice I use for TX: works in 2.3.9 but not in 2.4.9.
Tim K9WX
  • Dudley  WA5QPZ
    Dudley WA5QPZ ✭✭✭
    edited March 2020
    VOX over ride of DAX is not working in version 2.4.9, if that is a feature you have to have, best to drop back to 2.3.6 of SamrtSDR. I understand this was unintentional result of get remote DAX /SmartCAT operational. Dudley WA5QPZ
  • Tim K9WX
    Tim K9WX ✭✭✭
    edited November 2018
    Thanks, Dudley.  I was hoping it was me and that there was a setting I could flip to make it work.
    You mention a roll back to 2.3.6.  Did you mean 2.3.9?  I can't find where 2.3.6 was in general release.
  • Joe N3HEE
    Joe N3HEE ✭✭
    edited February 2019
    This is contest season folks !!!  Radios need to be working.  This is where Flex needs to offer a break fix patch to fix this problem.  Why make us wait months for a fix in the next upgrade ?  There will allot unhappy users this coming weekend in Sweepstakes SSB.  Including me.  Sure, I can roll back but I shouldn't have to ?
  • Joe N3HEE
    Joe N3HEE ✭✭
    I get MIC audio when using a foot switch connected to PTT jack on back of radio when DAX is enabled. This is far easier than rolling back to 2.3.9.  This is what I will do for SS SSB this weekend.  I will be running high power so using a foot switch is preferred to keep the amp happy.  Problem solved !
