SmartSDR v3.9.19 and the SmartSDR v3.9.19 Release Notes
Winlink/Winmor RMS Express and Flex6600-Fails to connect
Arvind Mallya
I have tried to install the latest RMS express on a Dell Desktop also running SmartSDR, I followed the steps provided by Tim of FlexRadio. Under device manager I see COM105 and Com5 as the Virtual Serial ports. I assigned Com105 to the Radio Control Port/ serial port and PTT Port/Serial Port to Com 5. In the SmartCat the Serial Com 5 is RMS Express and there is no Com 105. When I open the session in Winlink/Winmor and hit start it tries to connect and SendID and the Winmor Sound card displays the receive levels but no transmit. After calling out a station it fails to connect. Can someone please tell me what is wrong, when I hit the test transmit tone, there is no transmit tone like I saw in the video. The SmartSDR 2.9 version also takes a while to bootup on my Dell PC and show the connect bar to my Flex6600 radio. The PC is directly connected via Ethernet to the radio and sometimes I have to reboot the computer, it seems to show the Radio connect option intermittently.
Hi Arvind,
Here is a screen shot of my set up for ARDOP. Winmor & Pactor would be similar. Once the ARDOP TNC window launches, you can test Tx using one of several available methods, including CWID.
I use a 6600M with an I7 Win10 Dell laptop, and have no latency, slow-load, or other issues. The PC-CPU runs at about 25%. If I can help with anything specific just give a shout. Good luck!
Jim, WQ2H
WinMor and PACTOR are not similiar, as you would need a SCS TNC to run PACTOR.
I built a cable for my Flex65k5 and my P4dragon which works well. WinMor also works and my setup is similiar to yours. Vy 73, Alex - DH2ID0 -
For those interested, Farallon does make an off the shelf FlexRadio cable for the P4-Dragon - part # 9087. Plug and play.
Jim, WQ2H
Elmer and Jim, As you can see I do have receive signal but when I hit start on the winwor session I don't see anything transmitting, the DAX is on as shown blue, in the DAX control panel I had to make transmit yellow as highlighted. I switched ports and changed the TCP Port value to 8500 nothing seems to work.0
I just changed the TCP Port from 8500 to 8200 and now the DAX control panel Tx stream shows transmitting still no connection to the far end. I also don't see the Winmor sound card TNC Transmit lighting up.0
After changing settings TCP port settings to 8200, the DAX Tx panel lights up and showing transmission0
Comm ports assigned in Windows I selected 5 and 6. So far nothing still get failure to connect0
You need to turn your DAX on in SmartSDR console , so the DAX TX will connect your tx audio to SmartSDR.0
I turned my DAX on and the DAX window still says "DAX TX IS OFF".and mine won't connect either. RX works fine.1
Then you still have not enabled it in SmartSDR console window, the “TX Stack” , to the right of “Mic Gain” slider.0
Dudley, The TX is turned on in the Smart DAX, I will check now in the Smart SDR console, I thought that was ON.0
My console has "+ACC" to the right of the Mic Gain slider.0
Craig, the legend under TX is always says TX off but the TX button turns yellow and you see it transmitting with red indicator0
Craig, The bottom directly under the “ACC” button. It turns blue when enabled.0
Yep, that's selected. When I do a TX test in RMS I can see the audio TX data in DAX as it sends the test tones but my FLEX will not go in the TX mode. Have tried several PTT settings in the RMS Radio Setup but no go.1
GOT IT! Had to make a VSP for PTT. Now I see what the "P" is in the SMART CAT examples. Thanks.0
Craig, same here I see the same in DAX control panel go red and change up and down but don't see any thing in the Winmor Transmit Ack window. The receive looks fine and waterfall is active. I can also hear tge click of the switch in the Flex Rado change the frequency.0
Dudley, can you post a photo of what you mean by "Then you still have not enabled it in SmartSDR console window, the “TX Stack” , to the right of “Mic Gain” slider" In the SDR Console window up top I think currently it is RED is that in Transmit mode. Is that what you mean.
Your DAX is recognized in your second photo (Process = RMS Express) - which is good. I can't see you're entire CAT screen - do you have a P-com (PTT) to key the radio?
Two additional suggestions I would make: 1) adjust slice A Rx gain higher until it is 25-50% across the TNC receive level (make sure you're computer sound devise is at 100%) and, 2) do not enable DTR on either port - I've found that enabling this will halt all coms (on my set-up anyway).
Jim, WQ2H
Jim, Thanks, I'm linking a video on the entire start to stop process and when it goes to connect failure at the far end station, I will post the SDRCAT screen next. I do have a PTT on the radio does that need to be removed/disabled? I think I tried to move that receiver gain on the DAXCat window will try again and will check the Winmor TNC window and will make sure the computer sound is 100%. Where do you disable DTR?0
Jim and Dudley, short video showing the steps and then fail to connect https://s.amsu.ng/n9dyTYusHPBN0
Not sure why the link above fails, here is the same on YouTube
https://youtu.be/Xw_DDsJPoKA
Jim, I did change the port to Com5 and 6 photo shows the incorrect ports.
Hi,
I think you have to set your PTT port in
CAT so it is the PTT port. Look at my CAT
setup and you can see the CAT protocol for
COM 5 is set to P for push to talk.
73, Jim N9VC
- 342 Community Topics
- 612 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 173 SmartSDR for Maestro and M models
- 407 SmartSDR for Mac
- 266 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 374 SmartSDR API
- 9.2K Radios and Accessories
- 20 Aurora
- 199 FLEX-8000 Signature Series
- 919 Maestro
- 53 FlexControl
- 860 FLEX Series (Legacy) Radios
- 890 Genius Products
- 452 Power Genius XL Amplifier
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 442 Remote Operation (SmartLink)
- 137 Contesting
- 748 Peripherals & Station Integration
- 138 Amateur Radio Interests
- 971 Third-Party Software
