Band Edge on 6600M
Al Dewey
Al Dewey Member ✭✭
edited October 2018 in FLEX-6000 Signature Series
I am relatively new to Flex.  I received my 6600M in May and love it.  By doing a search, I know this topic has been discussed before on this forum several years ago but I thought I would ask it again to see if anything has changed.
I noticed during CQWW SSB this weekend that I was not allowed to transmit in the upper 2.8 KHz or so of the phone bands.  I understand that this is intended to be for my benefit so that my sideband does not transmit beyond the band edge. On 20 meters , for example, there was often a station transmitting between 348 and 349 that I simply was not able to call.  My two question are:
1) Are these band edge limits hard coded or it there a programmable parameter where you can set the band edge?
2) Is there a way to set a lower band edge?  I know that lower band edges depend on your license class.  However, I am probably more likely to accidently go too low in the phone band than go to high.
Again, I understand the reason but have mixed feelings about whether I like having that restriction imposed on me.
Al, K0AD
  • K3SF .
    K3SF . Member ✭✭
    edited October 2018
    note
    if they were 2.8khz band edge..most likely had some out of band transmit signal
    yes i do believe they are hard coded in the .turf files.
    BUT
    you can always reduce the bandwidth of your transmitted ssb signal to get close to band edges...instead o 2.7kkz try 1.8khz b/w. or even 1.5khz..you wont loose any readability ...
    and
    you can get closer to th eband edge and still be within the band with your signal
