Display frequency difference between WSJT and Flex 6xxx
DonS
DonS Member ✭✭✭
I am running WSJT-x v1.9.1 with the Flex 6700.  I noticed over the past month a frequency difference where WSJT-x is reporting 14.074.000 and the Flex is reporting 14.073.997.  I know this is only 3 hz, but, I have not had this issue before.  SDR v2.4.9. Any thoughts?
Don - kx9q
  • Ian1
    Ian1 Member ✭✭
    edited May 2020
    Hi Don I had this as well if I recall problem in in WSJTX recheck in settings for a offset and make sure you have 14.074.00 setup still. Also make sure fox hound isn't on. Ian
  • DonS
    DonS Member ✭✭✭
    edited January 2020
    I checked offsets and there were none.  When I changed the frequency on the flex to 14.074.000 then the frequency displayed in WSJT-X was 14.074.003.  This occurs without any transmission.
    The frequency does not change on the Flex when transmitting, however, there is an offset from 14.074.000 to the actual frequency. So everything is keyed off the primary frequency which in this case is 14.074.000 plus the offset shown in WSJT.
    Don
