the vox does not work
EA4AYW
EA4AYW Member ✭✭
edited January 2019 in FLEX-6000 Signature Series
good morning, I have the latest revision of the software 2.4.9.115.
when I went to operate the radio with vox, it turns out that it does not work.
the vox does not work, and the Mox does not work either.
to switch the ptt only and exclusively the Mox, but it does not have the audio of the microphone.
Only if I pulse the Ptt on the microphone does it emit audio.
I need a solution, this worked before perfectly.
Thank you.
  • FRED  W9TB
    FRED W9TB Member ✭✭
    edited January 2019
    I reported this to Tim he said it was most likely a bug and gave it a number. If you have dax on vox will not work. Every one I know that has 2.4.9 has the same problem. Look for a fix around Christmas.
