SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
Slice master Problem
I installed the latest version of slice master to receive the dx spots, but I think it was wrong because it does not recognize my flex 6400. the slice master program tells me this error: clock is not whitin tolerance clock- error 15203, no connection .
my flex is connected directly via LAN to the PC and the data reception is done via wifi. where am I wrong? do I have to set something internally at the SSDR?
Tnx in advance lou Ik8hcg-ig9r
Lou, When you first ran Slice Master, Windows should have asked you to allow a firewall exception. Did you allow it? Your description makes me think you might not have. WIthout the exception, Slice Master won't be able to use your network. The clock warning is only a problem if you try to use WSJT-X. To get rid of the warning, just make sure your computer's clock is set within one second of the correct time. --Don0
hi Don
tnx for your reply
slice master doesnt ask me when i run it anythink about firewall. No window open when i lunch the software ask me somethink.
i done a video i can send you via email0 -
Hi Lou, Windows will only ask the firewall question once the first time you run Slice Master. You'll have to open the Windows firewall settings and scroll down the list until you find the settings for Slice Master. You can change them there. You can send the video if you like, there's a support email address on the Slice Master splash screen when it starts up. But, your description was pretty clear. Take a look at your firewall settings and let me know how it goes. Feel free to move this conversation to email if adjusting the firewall settings doesn't help. --Don0
all work's righy now. Tnx. Does normal that on windows firewall folder there are two slice master.exe? i popped up all 3 squares for both .exe
just one and last questions. i would remove VE7CC.NET and put dxusa.net twhat should I put and write in the window
Great to hear it Lou. Let's just say that's normal-ish. Windows remembers the folder where you installed slice-master.exe. So if you've run it from two different folders, there will be two different firewall entries for it. Most folks just put it in one place and over write that place when new versions appear.
To get spots from dxusa.net just replace the line for ve7cc.net withtelnet://dxusa.net:7300
and hit the check box to re-enable the source and get the spots flowing.
--Don
I'm also having a problem connecting to my radio. Here are my firewall settings:
Thanks.0 -
Chip,
You can find my email address on the Slice Master splash screen. If you send me a copy of your config folder I can take a look at the logs. Just navigate to
C:Users<your user name>AppDataLocalK1DBO
then right-click on slice-master and select 'Send toCompressed (zipped) folder'. This will create a zip file that you can then attach to your email.
--Don0 -
I had some similar problems. Erased all the old versions of SliceMaster, then installed the latest version and it seems all is working now.
Pat de KA4VNM
I had the same problem that Slice Master didn't show any applications in the Launch screen. My problem was that I install all my apps on my D: drive and Slice Master looks for them on the C: drive.
I went into the Slice Master config.ini file and changed the default path name to the locations of my various applications.
- 419 Community Topics
- 719 The Flea Market
- 229 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
