N1MM+ SSB Stored Message Output Audio Level
Russ Ravella
Member ✭✭✭
Just got my first Flex and I'm working through setting everything up. I've got N1MM+ working in general. However, when I play a stored SSB message via the function keys, the radio keys up as it should, Tx DAX switches on as it should, nice clear audio in the headphones, signal appears on the meters and in the spectrum display as expected, but the drive level while present, is very low. Even if I turn up the DAX "TX Stream>TX Gain" all the way up, the drive level goes up a bit but is far lower than the strong clear audio I'm hearing in the monitor. Any idea what dumb moronic newbie thing I'm doing wrong? Thanks in advance for the help!
- 692 The Flea Market
- 119 Aurora
