SmartSDR v2.4.9 and Maestro RIT
K1ESE
Member ✭✭✭
SmartSDR v2.4.9 when using the Maestro, pushing the Slice A RX button used to allow the slice B knob to be an RIT control. Since upgrade that doesn't work. What setting am I missing?
It's still there
Having A-vfo active, long press on RX-button on B-VFO and you will have the RIT. IF B-slice also active the RIT will operate on B-slice frequency
Not the issue. It used to work on the RX button on slice A. It was a setting saying if Slice B is not used the long press allowed the Slice B knob to be used as RIT.0
Yes I know, I had the Slice B knob set up as RIT control for slice A. BUT until they do get the function back, it is still possible to have RIT for slice A on the slice B control, if you do what I said i previous post. Just to clarify, having only slice A active, a long press on RX slice B will invoke the RIT on slice A, and RIT tunes on slice B knob
Cheers
Yes, the workaround works fine. Thank you. I was really just trying to report what I suspected was a bug in v2.4.9, but thought maybe I set something wrong. It appears you noticed the same issue.
Again, thanks.1
- 683 The Flea Market
