Receive frequency shift
Gerald Schumacher
my 6600M has a frequency shift on receive on 160 meters the receive is 22khzz high on5mhz it is 55khz high the transmit seems to be ok. I have reset the radio twice reloaded the software nothing helped 73 w7ggs also is not the rit
Gerald, have you run the RX calibration? Goto Settingings, Radio Setup, RX tab and start the frequency offset.
Jeff N3VE0 -
Yes I have run the rx cal. and 6600M works fine tnx much.
- 683 The Flea Market
