Has anyone else had TeamViewer blocked claiming commercial use?
2»
  • W3EX -- Tom
    W3EX -- Tom Member ✭✭
    edited November 2018
    It's a great program and as long as you don't make connections from or to commercial addresses you will be fine.
  • Lucas - W6AER
    Lucas - W6AER Member ✭✭
    I have been using built in remote desktop with VPN (PC to PC) as well as LogMeIn for some instances, which I would NOT recommend any longer. They have raised the price to several hundred dollars per year ($840 to be exact, not a misprint) for a 5 pack license which I had for years. They also now bundle a lot of the other services nobody wanted to buy (such as a dropbox like service and a bunch of other ****) to justify the cost and they will not sell just RDP anymore. I called them to cancel and they gave me 50% off which buys me time to research alternatives and maybe rethink how I use it. I already turned off the auto-renewal and looking at other options. I also used it to remote administer servers so the free options would not work for me, but there is a line between paying for something and extortion. Just my two cents on what NOT to get anymore. Too bad, used to be a great company!
  • Jsi Ashuo
    Jsi Ashuo Member
    edited June 2019
    TeamViewer requires very expensive fees and costs $599 for every year. And when I was looking for an alternative, I found "hideasoft remote desktop", which costs $50 for a lifetime and is more powerful than TeamViewer. It can connect up to 1000 terminals and can support video conferencing. I think this is the only real alternative to TeamViewer.
    https://order.shareit.com/product?vendorid=200270322&productid=300946015&locale=en_US&cu...
  • Bob G   W1GLV
    Bob G W1GLV Member ✭✭
    I gave up on Teamviewer and switched to Microsoft Remote Desktop which works very well for me.
  • NA0B
    NA0B Member ✭✭
    edited June 2019
    There are several free alternatives to TeamViewer, some of them quite good. By the way, what is your call sign?
  • Bob G   W1GLV
    edited June 2019
    Jsi, the US dollar cost is 59.99.
  • Cal  N3CAL
    Cal N3CAL Member ✭✭
    edited June 2019
    I'm still using TeamViewer daily to access my shack via my Verizon cell hotspot.  I've been using for over 2 years now and never been shut down?   Works great!   Free License Ver 14.2.8352  ?????
    Cal/N3CAL
  • mlstutler
    mlstutler Member ✭✭
    edited June 2019
    If all you need is remote acces to your pc you should consider UltraVNC.  I have been using for years at work and use it for console access to computers where cant use keyboards.  Works great and is free.
    https://www.uvnc.com/
  • N8SDR
    N8SDR Member ✭✭
    edited June 2019
    Splashtop is another great remote application, years ago  as I do IT work Teamviwer nagged me then they wanted over 1500.00 to cover the clients I support, Splashtop costs me MUCHO LESS!!!! and with the Business Access plan I'm using I can resell seats to clients, friends etc. at reasonable cost!- the Audio interface works much better as well. https://www.splashtop.com/.
  • Tgary
    Tgary Member ✭
    If TeamViewer is flagging you, RDP plus VPN or Tailscale is cheaper if IT allows it. For quick help, I use HelpWire. It’s free and hasn’t given me issues
  • Mick  W8BE
    Mick W8BE Member ✭✭✭
    If all you need to do is remotely log into you device, I would suggest NoMachine. I have used it for over a year now at our club to access pc's remotely. It is free and works very well.
