Anyone using MAP65 and WSJT-x for EME successfully?
Tom Worthington
I've been using my 6600M with a DEMI 2m xvrt with WSJT-x successfully for EME contacts but I have been unable to add MAP65. I switched from running from the integrated panel to running on a locally connected PC because that seems to be the only way to get a DAXiq signal. Everything seems to set up correctly. I add another slice with DAXiq output and attach it to MAP65. I can adjust the DAXiq level with the preamp settings but and I can see some test signals but I don't ever get any decodes. Any suggestions would be appreciated.
73 and Aloha, Tom, NH6Y
- 692 The Flea Market
- 119 Aurora
