FTDI USB-Serial adapter question
Sergey KN7K
Member ✭✭✭
I do not think it is Flex related question, but decided to ask here anyway.
I have several FTDI adapters and used them without any issue last few years
https://smile.amazon.com/gp/product/B004WL7MIQ/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
Last month I started to use Flex and since than I cannot access them anymore even by using by supplied drivers on CD disk.
Adapter recognized as "USB Serial Port" , but in Properties says "reqiure furher installation".
I seems like it is Windows related question, but I just wonder if anyone has a quick solution. By the way same adapter recognized fine when connected directly to Flex6600.
Here what I have
Sergey, KN7K
Here what I have
Sergey, KN7K
Sergey , this FTDI cable from amazon works fine with my 6600
https://www.amazon.com/gp/product/B07589V742/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Ed0 -
Ed,
My adapter works fine with Flex, my PC stopped to recognize it.
Windows 10 64bit is here.
Sergey, KN7K0 -
I use the same adapter and Win 10 updates killed it every time. I found if I uninstalled the adapter in device manager and rebooted when it was reinstalled it then worked. I still use that adapter but went back to win 7 because I was tired of problems.0
it seems like Windows 10, killing drivers
Sergey, KN7K0 -
I use original adapters by FTDI from here https://www.ftdichip.com
On MAC, on any WIN, after any Win updates - trouble free
Currently in use with my 6700 adapters are running in Win10 x64 installed on Parallels for MAC
Everything fine since start with Flex6700 - July 2013
Sergey, probably you not follow exactly with drivers UM for you cables, recommendation is - disconnect cables before start installation wizard and only after completed you can plug in your usb-rs232 BTW, on screenshot above I can see you have a trouble with cm0com virtual driver ? Probably issue is in drivers conflict ?0 -
If you use the FTDI supplied drivers, you will be trouble free on Win10.0
Well, i do use supplied drivers. I have these adapters work for a few years in my PC without glitches. The only recent changes on my PC are Windows updates and Flex software install. I tried supplied drivers on CD and tried official drivers from FTDI website with the same results , as on image above. I have 2 different adapters, both recognized fine when I connect them directly to 6600 and I use one with Microham Station Master. Sergey, Kn7k0
Thanks Sergey, Adapters I use recognized by 6600 fine, windows see them as FTDI as well, so not sure why am getting VSP error. I may try to buy one from FTDI website for experiment. Thanks Kn7k0
Sergey,
I removed USB adapter and tried to install drivers again, it still failed to install VCP driver.
I also removed com0com as i do not use them anymore.
Anyway, i guess i will follow your advice and will buy one-two from FTDI website.
Could you tell me please which exact model did you buy?
Sergey, KN7K
What is going on here is that Windows has cached entries for that device, so even when you try to uninstall/re-install, it still knows the device from the old setup. (Which apparently was corrupted by windows update?)
I have had this problem on both windows 7 and windows 10, after using about 4 dozen USB thumb drives, external disk drives, several printers, and several phones and cameras and cables.
Once I have moved them all around to different physical ports a few times, things can get tangled up.
When I run into trouble with that (and I do not know if this is YOUR specific problem), I will use a utility to delete cached USB devices, and then re-install the driver BEFORE I ever plug that device in again.
The utility I use is called: USBdeview, a free software from NirSoft.
ref: https://www.nirsoft.net/utils/usb_devices_view.html
I can highlight any USB entry in the system, and delete every trace of it, like it was never ever
plugged into the system.
It is worth a try Sergey.
Cheers,
Neal N6YFM0 -
KN7K
Another possible problem would be leftover Ghosted Com Ports, which can block correct installation of com port drivers. Possibly, they could be com0com's ports leftover, but they will have to not be present.
here's a link to a guide on how to clean up the ghosts.
https://helpdesk.flexradio.com/hc/en-us/articles/200883925-Removing-Hidden-or-Ghosted-Com-ports
They can be tricky to remove, if you need assistance with it, find me in the #Flexradio IRC channel the link is in my post signature, use your callsign for the user nickname.For real-time discussions
User created documentation.
Volunteer!!73, Jay - NO5J
Hi Neal,
Thanks for your input.
I load USBdeview and found 5 FTDI devices listed.
So, what actions should I do?
When USB/RS232 adapter connected it is recognized by USBdview
Sergey, KN7K
If you have notes about how you wanted the ports configured, and can re-create your setup,
then;
1. Make sure USB devices cables are UNPLUGGED from computer.
2. Then, I select "Uninstall Selected Devices" on the above menu.
3. Reboot computer.
4. Make SURE that USB cables are still unplugged.
5. install device driver software for USB devices.
6. Only after the USB software device driver is installed, THEN re-connect USB cable.
Again, I am not sure if this was your specific issue, but the above is what I do to thorughly
clean out existing USB software and settings, so the computer thinks it has never seen the
device before.
Cheers,
Neal1
- 997 Maestro
