USB FTDI cable/null modem to SteppIR not talking
N8FNR
I bought a FTDI USB /Serial cable from Amazon made by Cable creation and one from UGreen. Plugged it into my 6400 and it was reconized by the rig. The SSDR USB setting is thus: cable type CAT,source Active slice, 9600, 8 N 1. Flow control none. Made a null modem cable with pins 2 - 2, 5 - 5 and 7-9 on the Steppir side. Set the Steppir controller (the old original version) to 9600 and rig type Kenwood. After hooking this up it the Steppir does not change frequency when I tune around. Tried both USB FTDI cables and neither work. But when I plug in my original serial cable that goes to my PC and run DDUTIL it does track frequency changes. Tested both USB FTDI cables with my KPA 500 and they both communicate with the rig so the are fine. Also verfied with a multimeter that the serial plugs are soldered correctly.
Any thoughts as to what I am doing wrong?
Zack N8FNR
Zack N8FNR
What did you do with pin 3?0
Not doing anything with pin 3. The instructions I found here were for only pins 2 - 2, 5 -5 and 7 - 9. https://community.flexradio.com/flexradio/topics/usb-cables-with-old-steppir-controller0
"I use a normal DB9 null modem cable (female to female, pins 2/3 reversing),"
Yea, below that it doesn't say anything about pin 3.
For 30 years, I have always known a DB9 serial had to have pins 2,3 (send,receive)
and pin 5, ground. A null modem adapter would cross pins 2 and 3 and leave 5 straight though.
I have my FLEX 6600 hooked to my StepIR controller with a USB cable and null modem adapter, and it works fine. And also a USB cable to my KPA1500, working great.
From the FLEX USB guide.. "...cross pins 2 and 3 will also work"
I will give that a try. Thanks!0
The flex guide isn't totally accurate. You need to wire 5-5 as well, which is the ground return for the SD and RD signals. In RS-232 speak it's called "signal ground". This is how I wired my cable, which works perfectly....
Pin 2 Blk ---- Pin 3
Pin 3 Red ---- Pin 2
Pin 5 Grn ---- Pin 5
Pin 7 and 9 are jumpered internally on each connector so that RTS is looped back as CTS.
73....Frank1 -
Hi, you just need the pins 2, 3 and 5. Do not care about the rest, they will come into the game when using Flow control. I do not know any modern serial device needing hardware flow control any more... 73 Henning0
Tried the above 2-3, 2-3, 5-5 and 7-9 on the controller side. Still no communication (sigh).0
Try plugging it into the data out port on the steppir.0
Tried the data out too but no joy.
Tried picking a different Source in the USB Cables setting. Now it says Type Invalid and I can't edit or delete it. Great. Can't believe that this is not working. It is just 4 wires on two connectors.
Put it back on the DDUTIL cable and it tunes just fine but still can't edit the USB Cables setting.0 -
Zack....you said you connected 7 & 9 together on the "controller" side. Do the same on the connector facing the radio as well. Also make double sure that your bit rate and parity config are consistent.
Just curious...why would you connect RTS to RI?0
Actually, I had a minor brain burp. Pins 7 and 9 need to be made common on the steppir controller connector only. They can remain unconnected at the radio end of the serial cable. The steppir controller uses them for some sort of TTL-level pass-thru. within the connector Not entirely sure why, but it's mentioned in a flex PDF regarding the different USB cable options.0
The USB Cable manual mentions crossing pins 2 and 3... 2/3 on this end go to 3/2 on that end, as well as the 7/9 connection at the Steppir end. 5 to 5 for ground too, though the manual doesn't say that explicitly. Looks like the CAT command comes from the Ant Controller, requesting the freq as per the source you setup in the radio, so the serial cable has to have both send and receive circuits in place.
Good Luck, Don0 -
Zack,
Take a look at this thread from earlier this year on this very same subject. Toward the bottom you'll see my post of the same cable info I've given you. In this case everything worked fine after he reworked his cable. Perhaps something else in this thread might be of help.
https://community.flexradio.com/flexradio/topics/usb-interface-and-steppir
Oh, and be sure you're plugged into the "Data In/Radio" port.
73....Frank
