Bluetooth Headset BlueParrott B450-XT with SSDR and Flex6600M
mikeatthebeach .
Have the Bluetooth Headset BlueParrott B450-XT with SSDR and Flex6600M
but when I try to switch to PC the Mic works but No sound when using Rx on PC laptop
Great Headset with Noise Cancelling ability, no matter what I do switching from Tx/Rx ( Mox)
on SSDR can not get both Headphone and Mic to audio work together on SSDR but works great on my Apple Smartphone & Apple iPad
Any Ideas
Maybe IOS with an Apple Product is the only way to get a VXI BlueParrott Bluetooth Headset to work
Can Pair it fine but only hear Audio, can Tx only if I with to PC in SSDR but then no
Rx Audio on Headset
Is this a V2.3.9 bug or did Flex not consider any Bluetooth HeadSets to work on PC 's
with SSDR
Folks get Bluetooth headsets to work fine on the Apple IOS devices just fine
but not SSDR with PC's - Issue in SSDR for PC's ???
Seems both ( Only Rx Headset ) or ( Tx Mic ) with not work due to SSDR on PC
have to toggle SSDR between Defalt ( Rx ) and PC (Tx ) which is useless for a SSB
contact !!!!
Since Bluetooth Headset only Work with Apple IOS devices since Flex SSDR
can not get to work routing the Audio properly on a PC with SSDR, only on
Apple IOS devices !!!! Go figure !
73 Mike
Any Ideas
Rx Audio on Headset
with SSDR
contact !!!!
73 Mike
Very interested to hear if any bluetooth headset will work. They work perfectly with other programs on my PC Windows 10 but not with the Flex SW. Maybe some simple setting but have not found it. Wired headsets work fine.0
Make a Voice SSB contact useless if using a Bluetooth device and a PC with
SSDR
Mike0 -
Make sure thee head set has been discovered by windows and in you "Sound Manager" make the Head set the Default Speakers and MIC on the PC start SmartSDR then on the AF (MIC) Input on SmartSDR select (PC) and on the TOP of the screen on the right hand side click on "PCAudio" so it is Blue.
Mine works great on several different Laptops/Computers running SmartSDR.
Once you get it set up save the Profile's to a name you can remember for the Bluetooth Headset.
73's
Bret
WX7Y
Bret,
Thanks for your reply
Yes, tried setting the SoundManager and Both Playback and Recording
are pointing to my Bluetooth but still same problem
I got a DAX Driver Error when I loaded V2.3.9 on my Windows 10 laptop
Next I did the Flex uninstall & reinstall of the Four driver, IQ-MICAudio, Rx and TX Audio
Yes, my PC Audio is BLUE and Mic is in MIC position but no MIC Audio
If I switch in SSDR from MIC to PC I get TX Audio transmitting but No RX Audio !!!
Killed any applications that might be locking up any of the DAX's at this Point
So at a loss at this Moment, If I had a Clean Windows Install and only
SSDR on the Computer, it would probably might work, I suspect the
Driver can not be loaded ( another program ?? CW Skimmer or WSJT-X
locking out a driver to install )
P.S: DAX Driver Error always there !!!
Starting to Hate Windows 10
Here the Error Message
First off does the head set work on something like Echolink or Skype?
If not then check your WINDOWS settings
On Windows 10 right click on the Speaker and "Open sound settings"
You should see your Blue parrot device in these two windows and should hear audio when you click on "device Properties" then click the advanced tab and click the "TEST" if you here tones out of the Blue Parrot then your speaker selection is correct.
Go back to the main windows that came up when you did the first step and look at the "Input" device below that you will see your Microphone device and below that will be a "Test your Microphone" with a line next to it. If your microphone is set properly then when you talk into the Microphone on the head set you should see Audio raising and lowering the Bar to the right of the little MIC Icon.
If you don't see anything moving on the Bar then click on device properties and click on the "Levels" tab and raise the MIC level up about 50% or so
DAX is a different problem then the MIC issue
If you are sure that your "Blue Parrott" Speakers and Microphone Devices ARE in fact set as the "Default sound devices" correctly and SmartSDR shows as I have Highlighted and it still doesn't work you may have something bad in your default Profile and you may want to try doing first a soft reset (turn Radio off then unplug the 12 Volt supply for 15 seconds or so) and give it a try, if that doesn't work then do a Factory reset and try these settings.
73's
Bret
WX7Y0 -
Bret
After Clean install of Windows 10 and new install of v2.3.9 things seems to work
One added thing, I save my working selections in SSDR to a Profile called
Bluetooth to avoid any confusion
Seems I have to be careful what sequence I power up the Bluetooth versus
Computer versus SSDR
Also overtime when I boot up PC, I have to check my Sound Manager, sometimes it does not come up properly and have to select / deselect it a few times to take hold
in the settings to hear Audio -- A Windows 10 feature for sure !
Thanks for your help, it is working so far with the Blue-Parrott B450-XT
Bluetooth Headset with it's Noise Cancelling mic on my Netbook PC
73 Mike0 -
That's great Mike, Windows 10 is a real joke on the way it handles audio and com ports and I'll bet it was Win10 issue all the time. Be sure to save a copy of the profile out to a separate directory out of the default FLEX directory for a archive, I have mine in a folder on the desk top so I an find them easier. Now your ready for the big time of running the Flex remote from ANYWHERE almost. 73 Bret WX7Y0
- 685 The Flea Market
