Maestro Battery Pack
Barry Young
Does the USB type connector in the battery pack have any cord on it? Because most battery packs are dual connectors. I was just wondering if there is any slack in the cable that can be used to maneuver the jack to the bottom or top jack of the battery pack. THANKS
Although the batteries are equipped with two connectors I've been told both cannot be used at the same time. (DON'T USE A Y ADAPTER to connect both sockets). One connector has a 2.4 amp output capacity, the other something less. Be sure to connect the battery to the 2.4 amp socket.0
The problem is that the connector is center with no “wiggle” room, I will have to get a small usb extension cable so I can actually plug it into the 2.4 connector that is offset of center. Hopefully Flex will change the design to a longer cable. Thanks!0
Check out the thread https://community.flexradio.com/flexradio/topics/biggesyt-battery-for-the-maestro. My solution, posted there, was to add a 1' USB extension cable. My solution, posted there, is:
So here is my fix. 1' USB extension cable stored in battery compartment when not in use. 2 rubber bands securing cover and battery (inside of cover facing up as it makes a nice cradle for the battery) to fixed base. Rubber bands positioned to clear fixed base rubber feet so base doesn't rock. All unnecessary if Maestro cable were an inch longer.
- 694 The Flea Market
- 357 FLEX-8000 Signature Series
