After upgrade cant get CAT control with WSJT-X
Ken AG2K
Ken AG2K Member ✭✭
edited July 2019 in Third-Party Software
After upgrading to 2.3.7 I can not seem to get WSJT-X set up to do FT8 anymore. I've tried to reconfigure per community instructions but just can't get CAT to work... I've seen the audio get through and do some decoding but no CAT..
Thoughts
Ken
AG2K
  • Mark_W3II
    Mark_W3II Member ✭✭✭
    edited July 2018
    Make sure you have selected the radio in the CAT program. Double check the virtual serial port that WSJTX is set to.
  • John - AI4FR
    John - AI4FR Member ✭✭
    edited July 2019
    Also try turning off CAT by task manager under processes. Even though I exit out of CAT it still stays active and at times WSJT does not work. Close it out as described above, then restart CAT and all should be well. Good luck with it and we'll be looking for you on FT8.
  • Ken AG2K
    Ken AG2K Member ✭✭
    edited June 2018
    Not sure what you mean CAT uses TCP port 60001. WSJTS is set for 127.0.0.1:60001
    Ken
  • Ken AG2K
    Ken AG2K Member ✭✭
    edited June 2018
    Did a reboot but still no luck.. do you know what is the name of the process that CAT uses?
    Ken
  • John - AI4FR
    edited June 2018
    Under task manager, under processes, it is called Cat.exe. If this doesn't work, try rebooting the PC and radio and starting fresh. If that doesn't work, then my guess is it is a setting someplace as Mark thought.
  • Mark_W3II
    edited July 2018
    I have successfully connected WSJT-X v1.9.1 with 6600M radio 3 ways.
    1. Using CAT TCP port 5004, WSJT-X set to Flex 6xxx 127.0.0.1:5004
    2. Using CAT Serial COM6, wsJT-X set to Kenwood TS-480 COM6 Baud 38400
    3. Using DXLabs DXCommander, WSJT-X set to DX Lab Suite Commander
  • Ken AG2K
    Ken AG2K Member ✭✭
    edited July 2018
    Fixed! Didn't realize that I had an older version of WSJT-X running. Ran the newest version and all works....
    Thanks for the help
    Ken
    AG2K
